auto to manual swap need help quick please
PostPosted: Fri May 03, 2013 1:14 am
by wolfman93
Can I use the auto flywheel with 5 speed?
PostPosted: Fri May 03, 2013 1:16 am
by Ajax1989
no..
auto have flex plates that the converter bolts to
mannys have a flywheel.. two diff things
PostPosted: Fri May 03, 2013 1:17 am
by wolfman93
:x damn it. Ok thanks
PostPosted: Fri May 03, 2013 1:20 am
by Ajax1989
stock d serise flex plate-auto
d series flywheel, also tells you the diff between efs
PostPosted: Sat May 04, 2013 12:20 am
by wolfman93
Auto harness work on manual?
PostPosted: Sat May 04, 2013 5:44 am
by Ajax1989
should you will have some extra connectors for the shift solenoids for the transmission, but for the most part everything is the same
PostPosted: Sat May 04, 2013 1:18 pm
by wolfman93
Ok thanks man
