motor/trans/clutch? issues
so one day i was driving down the road noticed a little knocking noise form engine only during first couple thousand rpms...thought...well rings are shot(or so i thought) maybe piston knock or valve train noise...never got any worse.....well drove 20 mies outside of town NO problems doing 55 the whole way, then went to turn put clutch in and car died....all lights came on.....parked car checked oil and whatnot...everything was good...started it back up sounded rough and like a metal gremlin was jumping around in my engine on crack...funny i know...gave it gas, started running better, backed up about 30 feet all good, shifted into first drove back into parking spot, gave car gas and died
.....would barely crank....thought to myself ...fuck just siezed engine
....but low and behold 6 months last when i buy a new engine and take old head off....motor is in tip top shape....next im thinkin WTF did i just drop 1300 bucks for nothing
....so im thinking maybe clutch is bad
. maybe tranny
...but no grinding or weird noises...everything just siezed....and like i said would BARELY crank over....never had a problem wiht car, well it started burning more oil and smoking a little...but figured out valve guides/seals were bad...but i sitll am trying to figure out what the eff happened..im still putting the new motor and trans in but i would like to rebuild this one and build it for boost or another car for the wife......like i said i looked at all the cyinder walls and pistons and aside form normal carbon build up looks to be in good shape...(walls are all clean so any ideas what i did...and motor is JDM d15b vtec with ex tranny and exeddy stage 2 clutch...drained oil in old motor to see if there were any metal shavings as well....none...need to drain tranny too but i really want to keep it for spare parts or another build....so ANY help would be FANTASTIC
. maybe tranny
