y4f trans??
PostPosted: Wed May 18, 2011 6:05 pm
by jetlikoki86
quick question guys, is the y4f same as the s20 trans?
PostPosted: Wed May 18, 2011 6:25 pm
Y4f is from 96-00, s20 is from a 92-95
92-95 trannys use an aluminum fork while 96-00 use a steel fork.
PostPosted: Wed May 18, 2011 6:59 pm
by jetlikoki86
what about internals, is it the same 4.25 final drive?
PostPosted: Wed May 18, 2011 7:11 pm
most internals are exchangeable... not sure if the FD ratios are the same or not. I've never tried. I googled & found this chart which may help:
http://hondaswap.com/reference-material ... ecs-29132/
PostPosted: Wed May 18, 2011 7:42 pm
by jetlikoki86
good info, y4f comes in the lx civic 96/00, so FD seems to be 4.05 coupe and 3.72 HB, thanks
PostPosted: Thu May 19, 2011 3:55 am
by Ajax1989
jetlikoki86 wrote:good info, y4f comes in the lx civic 96/00, so FD seems to be 4.05 coupe and 3.72 HB, thanks
:? why would honda change the fd ratio between makes..
i smell bs on that info
i work at a honda&acura trans shop
ill ask our manual builder tomorrow bout the fd ratio for u
and yes teal is correct on the forks
ill get back to u tomorrow on this if u like
PostPosted: Sat May 21, 2011 11:36 pm
by Ajax1989
its true, the coupe has a diff final drive then the hatch
idk why tho, that seems kinda stuipd
PostPosted: Sun May 22, 2011 4:30 am
by TrailerTrash
94_jdm_ferio wrote:its true, the coupe has a diff final drive then the hatch
any way to tell the difference other than pulling it apart and looking?
PostPosted: Mon May 23, 2011 12:54 am
by Ajax1989
well that info is for the lx trans for the 96-00 civic's
but not sure i can find that out as well
the lx and ex trans look identical
thats for the 5,6,and 7th gens, im not sure other gens
but its the insides that are diff
but ill find out
PostPosted: Thu May 26, 2011 3:15 am
by Ajax1989
other then the casting number and the vins
they all look the same
lx,dx,ex... for the ek and eg gens
