Throw Out / Release Bearing sounds like a cricket?
I have a brand new XTD 6 puck & 8 lb flywheel installed. Also I replaced the Throw out / Release Bearing with the new one that came with the clutch kit. I replaced the shaft/flywheel bearing too.
About 2 weeks ago, I niticed a very light squeak that sounded like a cricket always chirping. It was happening about 50% of the time when the clutch pedal was not pressed.
Fwd to now, the constant cricket chirping has gotten louder and happenes all the time. But if I press the clutch pedal in just a little, it stops. I only have to push it in to the point right before it starts to have any resistance to make the squeaking stop. The squeaking is coming from inside my tranny and it literally sounds like there is a big cricket in my tranny. A few days ago I checked my clutch fluid and it was a little low in the fluid tank, but not low enough to cause any driving issues. Everything works fine.
I thought Throw Out / Release bearings made more of a knocking sound when they needed replaced. This sound is just anoying, and it's constant unless I push the clutch in just a tad or more. The noise also increases with RPM, like the cricket chirps faster the faster I drive untill it just becomes a constant squeak.
I really don't feel like pulling my tranny out to check the bearing... do you all think that's what it is?
somethin is gettin hung up and causing the friction to make a noise
