Competition Engine Build
PostPosted: Sun May 03, 2009 8:02 pm
by Shanek
Hi
Planning on building a competition engine to run in a 1400cc class, Its going to be a low budget, I would be gratful for your advice on it and the best parts to use
The plan is to use a D14 Block with a SOHC vtech head bolted on to it.
Individual throttle bodies, was looking at GSXR 1000 throttle bodies
Fully mappable ecu.
Competition Cam
Y21 Gearbox with a close ratio gearkit and LSD (Will this bolt on to a D14 Block)
I am going to use an ESI 3dr Hatch as a shell as it will simplify wiring.
How much power do you think I would get out of this build.
PostPosted: Sat May 09, 2009 12:18 am
by Greasedmonkey
You can use any D series tranny. I think the y21 is a B series.
PostPosted: Sat May 09, 2009 2:30 am
by Benj
yah the y21 is a b series trans do you have a cable or hydro trans, cuz if you had a hydro one you could use one from an si thas from 92 to 99 i think and that has a closeish ratio
PostPosted: Sun May 10, 2009 7:09 am
by Greasedmonkey
yes, the 92-95 del sol Si, or EX/si civic tranny is a good one. It would be better though to grab a 96-00 EX tranny. They have stronger shift forks from the factory.
