Air leak from engine block
PostPosted: Thu Dec 25, 2008 2:29 pm
by Rossforest
Hi, I've just taken off my valve cover to give it a spray, however when I put it back on I can feel air leaking out of the top of the cover where one of the bolts had been snapped off by the previous owner. When I turn off the engine there is a hiss for a couple of seconds. Is this a big problem? Does anyone have any ideas how to sort it?
PostPosted: Thu Dec 25, 2008 4:58 pm
by Classiccarsrule85
well your best best would be to replace the said broken bolt area or it may have been a stud idk what motor your running....but anyhow that would be the best thing to do also i would get a new valve cover gasket set i would say tops 20$'s would get you one and then i would also buy for assurance a gasket sealant. tthen yea it should be fine after that....the hiss is just due to the leak i beleive thats what happened to my buddies when he had a leak himself. until he fixed it.
PostPosted: Thu Dec 25, 2008 6:40 pm
by Rossforest
I'm currently running a B16A2. Would driving with my engine with this leak be bad for it in any way? Will it reduce my performance? Sorry for all the questions, I only just bought by eg a week ago, loving it already though!
PostPosted: Thu Dec 25, 2008 7:03 pm
as far as i know the only thing that you are doing is killing some hp by allowing it to leak i think im pretty sure that its fine but really it should be fixed....
PostPosted: Mon Dec 29, 2008 6:13 pm
by Ej2-B16a
are you sure the hissing isnt from you building compression?
if you ever have done a compression test turning the motor over by hand you hearing air escaping thru the vavles
