minime swap question
Sat Apr 27, 2013 2:57 am
by wolfman93
Im going to build a minime but not sure of pistons. Which pistons should I go with? I want high compression and im using d15b7 block and d16z6 head. Going to build from ground up.
Wed May 01, 2013 6:17 pm
by nicksdelslow
Depends how high of compression u want. Is the car a daily or track car. And available octane grade makes a little difference also.
Look at zealautowerks.net select D series and play with ur options will give u a good idea of where to start.
Thu May 02, 2013 3:23 am
by wolfman93
Daily driver n occasional road course racing
Thu May 02, 2013 3:35 am
by Ajax1989
iirc its the pistons outta the dohc zc
Thu May 02, 2013 4:53 am
by nicksdelslow
The zc pistons will will put u around 10.5:1. If u were tobuse this set up u could deck the block or mill the head a combined .020 and still stay around 11:1 with nearly .05 piston to deck height. See below link just enter ur info and calculate until u get a set up u like.
http://zealautowerks.com/dseries.html
