Page 1 of 2
Piston rings.
PostPosted: Thu Sep 08, 2011 5:05 am
by Gustavo
So I was wondering where i could buy good quality piston rings for my b18b1? I am changing my stock rod bolts n since i'm that far down i might as well change my piston rings. R the 1's from password jdm or jhpusa any good?
PostPosted: Thu Sep 08, 2011 7:11 pm
by breez
jhpusa havent heard anything bad about them ..
Hastings is a good brand as well :thumb:
PostPosted: Thu Sep 08, 2011 7:19 pm
by Gustavo
breez wrote:jhpusa havent heard anything bad about them ..
Thanks. I looked at jhpusa n they r cheaper than password jdm.
PostPosted: Thu Sep 08, 2011 11:25 pm
by breez
no problem good luck with the build ! :D
PostPosted: Fri Sep 09, 2011 2:56 am
by Gustavo
breez wrote:no problem good luck with the build ! :D
Thanks. I'm still deciding if i wanna do this now or wait a little longer cause i'm about 2 start school again.
PostPosted: Mon Sep 19, 2011 10:42 pm
by Fada Blayne
gow bad do u need the rings? how do u even know u need rings?
PostPosted: Mon Sep 19, 2011 11:00 pm
by Gustavo
Fada Blayne wrote:gow bad do u need the rings? how do u even know u need rings?
I don't need them but would like 2 replace them now since im gonna have everything torn apart.
PostPosted: Mon Sep 19, 2011 11:55 pm
by Fada Blayne
oh i see. are u going to be honing your block?
PostPosted: Tue Sep 20, 2011 1:47 am
by Gustavo
Fada Blayne wrote:oh i see. are u going to be honing your block?
Honing?
PostPosted: Tue Sep 20, 2011 2:38 am
by RWMIII
Honing?
Engine honing is the process in which a mechanic uses fine-grade stones to deglaze the cylinder walls of an engine block before the pistons are put back into the engine. This assures a tight, leak-free fit between the piston rings and the cylinder walls
Read more: The Block Cylinder Honing Process | eHow.com http://www.ehow.com/how-does_5149925_bl ... z1YSMVYxY9
http://www.ehow.com/how-does_5149925_bl ... ocess.html
PostPosted: Tue Sep 20, 2011 5:08 am
by Gustavo
RWMIII wrote:
Honing?
Oh. Not really sure if the machine shop was gonna do that. But next time i talk 2 him i'll ask.
PostPosted: Tue Sep 20, 2011 5:39 am
by RWMIII
If it is a good machine shop, then they should do this.
PostPosted: Tue Sep 20, 2011 2:19 pm
by bks84
I've used total seal once before with good results. Im not expert on piston rings, but as long as their properly gaped and installed I dont think the brand matters much...
PostPosted: Tue Sep 20, 2011 5:01 pm
by Fada Blayne
and if your now going to hone then i dont suggest you getting new rings just yet
PostPosted: Tue Sep 20, 2011 5:07 pm
by forcefedEG
Total seal are what I've had the beat results with in the past :thumb:
