Oem key blanks.
PostPosted: Fri Dec 30, 2011 7:23 pm
by Apexracing
Any one know where to get some oem honda key blanks my ej only came with one key.
PostPosted: Fri Dec 30, 2011 7:31 pm
by FG2_Andrew
i saw a couple on ebay the other day.
http://www.ebay.com/itm/GENUINE-HONDA-O ... 4ab23083ac
PostPosted: Fri Dec 30, 2011 7:38 pm
by Apexracing
Sweet thanks ill pick up some later.
PostPosted: Fri Dec 30, 2011 7:45 pm
by FG2_Andrew
welcome brother! :D
PostPosted: Fri Dec 30, 2011 9:54 pm
by dbrooks
I buy mine off of Ebay. I have about 5 blanks. You can go to honda and they'll but you one of the OEM keys for about $15 and it works awesome. It's not like some hardware store cut that only works half the time.
PostPosted: Fri Dec 30, 2011 10:22 pm
by Apexracing
Yea i was going to try honda tomorrow first. I tried home depot and i might as well use a screw driver for my locks and ignition
PostPosted: Fri Dec 30, 2011 10:44 pm
by dbrooks
Yeah, it's nice having a REAL key for your car. I cannot stand the "hardware store specials" Hahaha
I got locked out of my house for about 8 hours one time, so I don't get spares at hardware stores anymore....
PostPosted: Fri Dec 30, 2011 10:49 pm
by Apexracing
Yea they have a auto cutter and the blank they used is too long. So i have to put the key in almost all the way to use it. Why cant people just hold onto their keys damn it.
PostPosted: Fri Dec 30, 2011 11:10 pm
by asianrob
honda would be the cheapest in my opinion bring your title and like 5 bucks to get your master key made i think the keys from them are only a couple bucks each.
PostPosted: Fri Dec 30, 2011 11:11 pm
by Apexracing
asianrob wrote:honda would be the cheapest in my opinion bring your title and like 5 bucks to get your master key made i think the keys from them are only a couple bucks each.
I cant bring my tittle i just bought the car :(
PostPosted: Tue Jan 03, 2012 4:22 am
by ImThaBean
You don't need the title, just the registration and ID matching name/address.
They will cut it for you based off the VIN.
Worst case, if the cutter is broken (99% of the time at my dealer), they will give you a code and send you off to a local locksmith that they trust. I have had keys cut by the dealer and the locksmith. both worked flawlessly.
Also, I like the Accord/CRV key over the civic key. it has more surface area.
http://www.ebay.com/itm/Honda-Key-Blank ... 4159efb43d
PostPosted: Tue Jan 03, 2012 12:38 pm
by FG2_Andrew
ImThaBean wrote:You don't need the title, just the registration and ID matching name/address.
very good to know. i want an OEM key made and my locks/ignition all the same cut.
PostPosted: Tue Jan 03, 2012 3:53 pm
by Classiccarsrule85
just fyi last time i went to get keys made for my 1992 civic they said the bubble was around 1994 or so. which means im fucked if i ever lose the keys to my crx etc also the little numbers on top the 4 digit or whatever those numbers are golden write them down before they wear away or then your really screwed if you lose your key because they told me the bubble may be closing on the civics etc but thats just because our database can only hold so much but if you have that number they should be able to make your key oem exact fit without a spare key....
anywho yea go to honda and make sure you have some form of ownership that tells them you own the car etc
PostPosted: Tue Jan 03, 2012 4:12 pm
by Apexracing
Yea got to wait for my tittle to arrive. Then have like 3 keys made cause my oem on i have now sucks too lol.
PostPosted: Tue Jan 03, 2012 11:25 pm
by asianrob
its probably different in your state then, my local honda dealer asks for the title for the master key.
