- Thu Sep 18, 2008 4:58 am
#70276
So I've disconnected everything (hoses, wires,plugs,sensors,etc) from my engine as Im goin to drop it out for a rebuild. But Im stuck on the axles. The axle nuts are off and the shock forks are off. Theres 3 ball joints around for each side (upper CA, lower CA and the steering). The nuts are all loosened I just cant seem to break any one of the joints loose. I've searched around but haven't found anything. Anybody got any tips??
Undo the shock/coil assembly and have someone hold it while you give a good whack at the end of the axle to get it out of the hub.
Should be as easy as that.
Taking it out of the trans you can do with just a pry bar or big screw driver.
To Them, they're just vehicles. To Us, they're a way of life.
