- Thu Jul 24, 2008 3:53 pm
#63222
Hey guys, i just cleaned out my throttle body and for some reason my engine is idling higher than it should. My CX doesn't have a tach so i don't know how much higher.... I'm guessing 300rpm. The rpms slowly jump up and down and the exhaust pops a little. Its eating up my gas and its a little bit too loud at stoplights. It seems to idle lower when rolling in gear. Is there anyway i can adjust my idle??? Or did i do something wrong when i put the trottle body back on. Thanks guys!
Try getting a flat head and turning it. And or check your IAC. If the idle is going up and down your IAC could be clogged with carbon. Just take a quick minute and check over a few things. Also look at the vacuum lines make sure they are all in place and in the correct spots.
To Them, they're just vehicles. To Us, they're a way of life.
