Engine problem
My engine acts funny under 3000rpm. Not giving me full juice. When starting from standstill I have to give it quite much gas or else it will cough and jump a bit. Checked CEL end it blinks constant. I counted over hundred blinks before I gave up. I checked my ignition. It is on the white marker just 2 mm to the right of the red (D15B7). I think it is supposed to be on the red. Is there any way of checking my timing belt position with out removing the crank pulley? (It is stuck like h... tried 1,5m leverage with me on top.). What else should I be looking at? O2 sensor? Coil?
Help is much appretiated appritiated
