By BlackKight
#35739 I can't get my 92 Honda Civic started... At first I thought it was because of the battery and I took it to Autozone to check on the battery, but the battery is still good... So I don't know what is wrong with it... There is no check engine lights... So I don't know what is going on with the car, I check all the fuses and there isn't any that is blown...
#35741 does your starter click?
#35742 Need more info.
Whats going on.....
Starter making any noise?
Any relays click when you turn the car on?
Give us as much info as you can. :thumb:
By BlackKight
#35743
ChicagoMike wrote:Need more info.
Whats going on.....
Starter doesn't make any noise... and when you put in the key to start the car there is no clicks... but the alarm just chirp... it doesn't chirp loud but it chirp like the battery is dying... I couldn't even turn on the head lights...
#35761 Bad ground, or clean your battery connectors with sandpaper or a terminal cleaner.
By darkdevil
#35769
Graham wrote:Ignition going on, and is the fuel pump priming?
We cannot turn on the ignition, and the fuel pump is not priming too...
#35773 Main relay maybe? :?
Graham wrote:Immobiliser................
haha, ya is this car in an impound lot?
J/k :thumb:
By Ej2-B16a
#35809 Really sounds like a bad ground somewhere....
By darkdevil
#37049
Ej2-B16a wrote:Really sounds like a bad ground somewhere....
I was wandering where does all the ground located at?
By darkdevil
#37050
teal_dx wrote:did you recently do any work to the car before this happened?
The previous owner did an engine swap... So when we got the car the v-tec isn't kicking and had to rewired the whole v-tec harness... Also the deck cd player isn't working also because the previous owner burned the harness... So we had to wired the deck from the battery in order to have the deck to work...
ChicagoMike wrote:Main relay maybe? :?
Its a Possibility. I had similar issues in the past like this.
I would check the grounds on your battery as the people said before.
When you replaced your burnt wiring did your car start after that? if not then there might be your problem.
