- Fri Oct 07, 2011 9:01 pm
#276682
Recently started smelling gas with the windows rolled down but only when I fill up half tank or over. Not like exhaust but straight gas. Please let me know of any common fuel leaks. I've checked the following:
fuel filter
fuel rail
injectors
injector o-rings
fuel lines under car
replaced fuel tank cap
fuel pump cover under rear seat
What's the best method for finding a fuel leak? I've searched high and low. I even read somewhere that cracked headers or a bad exhaust manifold gasket can cause the o2 sensor to think you're running too lean and send too much fuel to the engine. I'm stumped!
fuel filter
fuel rail
injectors
injector o-rings
Ok , at least I know I'm on the right track. Now for phase 2 lol, how can I find a header leak. I can't spray soapy water it will just burn right off (duh).
