need help locating pcv
Thu Mar 17, 2011 6:24 pm
by chewse
Is that...
Thu Mar 17, 2011 6:53 pm
by Stokes
What engine is it dude? Does it have an aftermarket inlet manifold?
I can't work that picture out
Thu Mar 17, 2011 7:14 pm
by chewse
Jdm d15b dual carb...identical to d15b4
Thu Mar 17, 2011 7:17 pm
by chewse
Fri Mar 18, 2011 4:34 am
by Greasedmonkey
get us a better picture of the manifold itself.
what ever is in the picture doesnt look like a PCV to me.
Fri Mar 18, 2011 11:09 am
by chewse
Fri Mar 18, 2011 11:56 pm
by chewse
Hey I jus remembered I had a motor in the backyard so I checked it out and I remove this
. From this black box located just above the oil filter
can this be related to the pcv or is this where it is located
Sat Mar 19, 2011 5:43 pm
by suspendedHatch
Is that just an open valve or is there a check ball inside? The PCV will have a check ball, but those older engine designs didn't use one. You can follow that hose to the intake manifold to verify that there's no PCV.
I've only seen those intake manifolds on 3rd generation Civics.
Sat Mar 19, 2011 7:53 pm
by chewse
The plastic piece in my hand didn't have anything on the inside it was just hollow I'm startin to believe I don't have a pcv but ii will try to follow that hose and see where it leads
Wed May 04, 2011 7:44 pm
by bserius
im almost positive that is where it shoulda been so maybe it needs a new 1 put in there
