squealing sound
my car squeals every time I turn it off. It's a short squeal, doesn't seem to effect performance, but it does get annoying and it's kinda embarrassing. No idea what it is, hope someone can shed some light on this.
Torch_Ind wrote:is your belt loose?
ct126x wrote:Torch_Ind wrote:is your belt loose?
timing belt? how do i tell? do i just pull on it?
Torch_Ind wrote:ct126x wrote:Torch_Ind wrote:is your belt loose?
no normal serp belt is what i was talking about. if it's coming from the timing belt get it looked at.
you can take your serp belt off and try that to see if the noise is gone with it off
dro21 wrote:Someone correct me if im wrong..But i think if you remove your timing belt your timing will be off!?
