- Sat Apr 16, 2011 11:48 pm
#250759
i pulled off the distributor cap. it looks normal. i cleaned all the conacts and sealed it back on tight. i checked all fuses and grounds. i drained the gas tank completely. then added a bottle of heet with a fresh tank of gas. i went to relieve the fuel pressure from the top of the fuel filter, and nothing came out. so i tore out the back seat, and opened up the fuel pump cover, turned the ignition switch on, and i didnt hear any sounds coming from my fuel pump. now i am thinking i need to pull the pump out, and check resistance and clean the sock (and possibly replace the pump). i will let you know what happens. any suggestions would be helpful. thank you.
i forgot to mention, she doesnt even start up now.
176,000 and still rollin...well sort of =)
