- Sun Feb 06, 2011 10:16 pm
#237344
What's up guys I was doing some research online and I came up on a boosted mini me build. So I was wondering how much psi I can run my b7/z6 mini me motor. I know its a high comp. At first I didn't. Believe it till I saw a video on YouTube of a mini me boosted...so I'm needing ur guys advice, cause I have a 14g Turbo laying around. Will a small Turbo be better for fast spooling for this build. If its okay to boost the mini me.
if you used a z6 head gasketit would be 10.22 to 1
either is fine to boost
im not sure how big a 14g turbo is but im pretty sure its on the small side
that being said id run like 8 to 10 psi with a GOOD TUNE
it also depends on how good of condition the bottom end is in
first thing id do is a compression test and see if the b7 block can handle it
and yes you want a small turbo for better response on our little d series
if you can run 8psi on a healthy motor it should be around 160 - 170 whp just guestimating
my build> blue bandit-sold=[
http://civic-eg.com/viewtopic.php?p=203107#203107
taco build!
http://civic-eg.com/viewtopic.php?t=17613
taco build!
