- Wed Mar 25, 2009 10:36 pm
#105728
hi just signed up.... owned a 2000 but some chick stole it and went on a 3 car police chase, but it ended well because I just bought a 93 eg hatch . I have a couple of questions , what eg is the one with the 1.5 nonvtec and no options (the one i bought) , secong how hard is it to do the b16 swap, meaning what do i need altogether besides the motor, tranny, and ecu?
- Thu Mar 26, 2009 2:52 am
#105793
Probally a CX. you can tell by the engine saying "8valve" or something on the valve cover.If it says 16valve then you have a DX.
on the b16 swap you will need the following, Assuming you have a 99-00 Civic Si B16.
B16 engine/tranny
94-01 Integra Mounts, You might be able to use your 99-00 Civic mounts, dont know if they will work. Never read into that. However i know 94-01 Integra mounts will work.
94-01 integra shift linkage, Agian you might be able to use your 99-00 Civic linkage, I know for a fact you can use integra linkage though.
ECU
You will also need OBD2a to OBD1 conversion harnesses. on the ecu. You can use the injectors and distributor from your d15 to make your engine obd1. You will have to do something about your map sensor, don't recall what and want to reuse the speed sensor out of the D15(keeping everything obd1)
