- Fri Nov 21, 2008 12:25 pm
#79719
Hello. The Honda Language post is great, but we need a master list. And since I have nothing to do for the next two hours, I decided to contribute.
If anyone has anything to add, please post it and I will try to keep it updated as much as possible. I am active duty so it might be a few days in between.
Also note: A lot of this stuff was copy/pasted, and I added a few myself. I'm not trying to steal anyone's work, just trying to help out.
Big thanks to all the contributors on the first post, especially egferio95, k20a_da, Bouli and Sire.
Section 1: Acronyms & Abbreviations
2WS = two wheel steering
4WS = four wheel steering
ABS = Anti-lock braking system
A/C, AC = Air conditioning
A/F, AFR = Air/Fuel ratio
ATF = Automatic transmission fluid
B16 = B16 Engine code. See section 3
B18 = B18 Engine code. See section 3
BHP = Brake horsepower
BOV = Blow off valve
CAI= Cold air intake
CC = Cool chamber
CEL = Check engine light
CF = Carbon fiber
CR = Compression ratio
CROME = Cui ROM Editor
CTR = Civic type R
D15 = D15 Engine code. See section 3
D16 = D16 Engine code. See section 3
DA = 2nd generation Integra
DIY = Do-it-yourself
DOHC = Dual Overhead Camshaft
DOT = Department of transportation
DP = Downpipe
DPFI = dual point fuel injection
DRL = Daytime running lights
ECM = Another name for ECU, engine control module
ECU = Electronic Control Unit
EDM = European domestic market
EG = Certain 5th generation Civics
EGR = Exhaust gas recirculation
EGT = Exhaust Gas Temperature
EK = Certain 6th generation Civics
EPROM = Erasable Programmable Read Only Memory
ET = Einpress Tiefe (offset)
FF = Front engine, front wheel drive
F/I = Forced Induction (turbo/SC)
FIV = Fast idle valve
FMIC = Front Mounted Intercooler
FMU = Fuel Management Unit
FPR = Fuel Pressure Regulator
FR = Front engine, rear wheel drive
GSR = Integra GSR
HG = Head gasket
HID = High intensity discharge
HP = Horsepower
IAB = Intake air bypass
IACV = Idle air control valve
IAT Intake air temperature sensor
IC = Intercooler
I/H/E = Intake, header, exhaust
ITB = Individual throttle bodies
ITR = Integra type R
IM = Intake Manifold
ITB = Individual Throttle bodies
JDM =Japanese Domestic Market
KPH = Kilometers per hour
LCA = Lower Control Arm
LED = Light emitting diode
LS = Integra LS
LSD = Limited slip differential
MAF = Mass airflow sensor
MAP = Manifold Absolute Pressure
MPG = Miles per gallon
MPFI = Multi-point fuel injection
MPH = Miles per hour
MR = Midship engine, rear wheel drive
M/T, MT = Manual transmission
N/A, NA = Natural Aspirated, Not applicable
OBD1 = On Board Diagnostics version 1
OEM, OE = Original Equipment Manufacturer
PCV (valve) = Positive crankcase ventilation valve
PGM-FI = Programmed Fuel Injection
P/S, PS = power steering
PSI = pounds per square inch
PU = Polyurethane
RHD = Right hand drive
ROM = Read Only Memory
RPM = Revolutions Per Minute
RTP = Real Time Programming
RWD = Rear wheel drive
S2K = S2000 Honda
SAFC = Super air flow controller
SC = Super Charger
SMIC = Side mount intercooler
SOHC = Single Overhead Camshaft
SRI = Short ram intake
STB = Strut tower bar
TB = Throttle body
TCC = Total Car Concept
TCU = Transmission control unit
TCM = Another term for TCU, Transmission control module
TDC = Top dead center
TMIC = Top Mounted Intercooler
TPS = Throttle position sensor
USDM = United States Domestic Market
USB = Universal Serial Bus
VAFC = VTEC Air Flow Converter
VTEC = Variable valve Timing and lift Electronic Control
WAI = Warm Air Intake
WB O2 = Wideband Lambda sensor
WG = Waste Gate
WHP = Wheel horsepower
Section 2: Terminology ...More coming soon! Please contribute! Some of the stuff in section 1 could really use an explanation.
Altezza taillights = taillights resembling the Lexus IS/Toyota Altezza taillights, red w/ chrome housing.
Ballast = A device used to regulate the incoming voltage for an HID lighting system.
Bi-Xenon = HID headlamp parts capable of both High and Low beam from the same bulb and housing.
Brake horsepower = measurement of an engine's horsepower without the loss in power from the transmission, alternator, power steering pump, etc.
Camber = angle of the wheel relative to vertical, as viewed from the front or the rear of the car.
Cylinder head = housing for the valves and the camshaft(s), mounts on top of the block.
Exhaust manifold = first series of tubing that the exhaust gases pass through to exit the engine. connects to the downpipe and cylinder head.
Intake manifold = Air travels through here to reach the engine. connects to the cylinder head.
Long block = block + cylinder head
Mini-me = non-vtec longblock with vtec head
Projector = a type of headlight that utilizes a lens to focus the beam.
Short block = block only
Wheel horsepower = the power actually turned into forward motion, after it has gone through the transmission, alternator, power steering pump, etc.
Section 3: Engine codes, model years, horsepower rating
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp
D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130ps
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K20A3 2.0L DOHC i-VTEC '02+ RSX 02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S 02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps
F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp
F22A1 2.2L USDM non-VTEC 92-96 Prelude S 90-93 Accord LX/EX 130hp-135hp
F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL 150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiRS Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps
C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp
C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP
C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp
J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
CC = Cool chamber
CF = Carbon fiber
CTR = Civic type R
DP = Downpipe
GSR = Integra GSR
HG = Head gasket
HP = Horsepower
IC = Intercooler
LS = Integra LS
PU = Polyurethane
S2K = S2000 Honda
SC = Super Charger
TB = Throttle body
WG = Waste Gate
