CAR IDLES AROUND 3K
PostPosted: Wed Feb 18, 2009 3:48 pm
by JDM FERIO BOYZ
ok its a single cam yeah. but when i turn on the car it idles right off the bat at like around 3 grand. no tach yet but sounds like it. and it never idles back down? any ideas? maybe vacuum hose?
PostPosted: Wed Feb 18, 2009 4:20 pm
by OmarG
have you messed with throttle body lately? Or the little cable thingy?
PostPosted: Wed Feb 18, 2009 4:43 pm
maybe your throttle cable is too tight or maybe you have a vac leak or maybe you should clean the FITV (in that order).
PostPosted: Wed Feb 18, 2009 4:58 pm
by vtec_gloucester
air leak, idle control valve, air in the coolant... theres a few that you can check.
PostPosted: Wed Feb 18, 2009 5:01 pm
by Xaser
teal_dx wrote:maybe your throttle cable is too tight or maybe you have a vac leak or maybe you should clean the FITV (in that order).
I would go with that, and if your idle is a little rough, I would check leads and distributor.
PostPosted: Wed Feb 18, 2009 5:11 pm
by JDM FERIO BOYZ
alright cool. ill check it out. thanks. im sick of siting a red light and me be loud as hell. lol
PostPosted: Mon Feb 23, 2009 8:19 am
by perry83
Had the same problem with my old Integra. Was a bad idle air control valve.
