Motor mount differences (confused)
PostPosted: Sun Jan 12, 2014 6:36 pm
by vasquezkito
I'm looking to buy motor mounts but each time
I look for some I run across "3 post bolt" and
"3 post bolt w/ hydro tranny"
And idk what the differences are cause on my oem
Motor mounts my driver side has 2 holes an on my
Passenger it has 3 holes an idk if there's a difference or
It wouldn't matter which one I get ..
I would appreciate the help
PostPosted: Mon Jan 13, 2014 2:22 pm
I'd post pics and links to the mounts you're buying to be sure, but it sounds like you're referring to the 3-hole tranny mount. If yours has 3 holes, then that's the one you need. But post some pics to be sure. :thumb:
PostPosted: Tue Jan 28, 2014 8:03 pm
by blk92hb
The 3 bolt mounts are the driver side mount. If yours is a 2 bolt then that's what you want. Are you planing a motor swap??
PostPosted: Wed Jan 29, 2014 5:13 pm
by HeikDiesel
They are talking about the cast mount that bolts to the timing belt side of the engine. If it has two attachment points its a two post (civic) and if it has 3 it's a 3 post (integra)
PostPosted: Fri Feb 21, 2014 3:49 pm
by xzachrickx
BOOM SON!!! thats what i was about to say
HeikDiesel wrote:They are talking about the cast mount that bolts to the timing belt side of the engine. If it has two attachment points its a two post (civic) and if it has 3 it's a 3 post (integra)
PostPosted: Fri Feb 21, 2014 6:57 pm
by jefferydclark
xzachrickx wrote:BOOM SON!!! thats what i was about to say
that's not always true. all EX model civics with a d16z6 has 3 bolts on the driver side as well. that being said. all(American) 92-95 vtec civics and 94-01 integras have the same mount kits. all d15 nonvtec engines in America have 2 bolt post design on the driverside.
PostPosted: Fri Feb 21, 2014 6:59 pm
by jefferydclark
i'll make note that jdm d15b vtec engines have 2 post design so that can get a little confusing to a newb in the Honda world. nothing to be ashamed of though. we're all learning.
look at your mount beside the timing belt. if you see just 2 studs with nuts on it then you have the 2 bolt design. if you see 2 studs and a bolt(bolt sits lower) then you need the 3 bolt design. if you're still unsure, post a picture and we can tell you what you need to order. since you have a DX model civic, I want to go out on a limb and say you need the 2 bolt setup unless you've got an engine swap in there.
PostPosted: Fri Feb 21, 2014 11:57 pm
by HeikDiesel
They may all have the same mount kit but they always make you clarify if you need a 2 post or 3 post LH mount. To my knowledge I thought all civics were 2 post so my apologies for that but that's still the question he was asking.
