Driver door doesnt unlock from outside
Mon Jun 17, 2013 10:22 am
by kutthroatkrow
As the title states among my many problems I now have a new one. The key won't unlock the car from the outside. It will happily lock it all day, but won't even attempt to unlock it. The interior latch works just fine for both operations, but I don't think it very smart to leave my window down 24/7 despite my car being auto. Any ideas?[/u]
Sun Jun 23, 2013 2:18 pm
by panic989
WD40 in the locking mechanism from the key side and behind the inner door panel maybe?
Mon Jun 24, 2013 7:09 am
by nicksdelslow
I have noticed with multiple eg's it sometimes helps to pull the putter handle just a bit to lock and unlock. My sol is bad about not unlocking without pulling out on the handle a bit.
Mon Jun 24, 2013 5:38 pm
by nd1983
nicksdelslow wrote:I have noticed with multiple eg's it sometimes helps to pull the putter handle just a bit to lock and unlock. My sol is bad about not unlocking without pulling out on the handle a bit.
i have to do this with my drivers door on my eg8 when locking the door from inside
Mon Jun 24, 2013 8:30 pm
by HeikDiesel
nd1983 wrote:nicksdelslow wrote:I have noticed with multiple eg's it sometimes helps to pull the putter handle just a bit to lock and unlock. My sol is bad about not unlocking without pulling out on the handle a bit.
This is normal
Mon Jun 24, 2013 9:11 pm
by nd1983
HeikDiesel wrote:nd1983 wrote:nicksdelslow wrote:I have noticed with multiple eg's it sometimes helps to pull the putter handle just a bit to lock and unlock. My sol is bad about not unlocking without pulling out on the handle a bit.
This is normal
whats the cause of it? as this could be the cause of the OP's issue aswell
Tue Jun 25, 2013 6:15 am
by kutthroatkrow
Nah the inside locks and unlocks fine. Yes you have to pull the handle on the inside, its security. I'm talking about the key not working in the door anymore.
Tue Jun 25, 2013 1:17 pm
by HeikDiesel
nd1983 wrote:HeikDiesel wrote:nd1983 wrote:nicksdelslow wrote:I have noticed with multiple eg's it sometimes helps to pull the putter handle just a bit to lock and unlock. My sol is bad about not unlocking without pulling out on the handle a bit.
This is normal
I think it's supposed to help from locking keys inside. OP's problem sounds like the linkage from the key to the lock has problems whereas the inside lock linkage is fine. I'm sure as soon as you pull the door pannel and plastic you'll see the problem
Wed Jul 03, 2013 5:16 am
by kutthroatkrow
Well I completely disassembled my door to fix the regulator and everything is hooked up. Kinda feels like I have the wrong key, but my ignition only works with my key, curiosity begged me to try my friends key.
Thu Jul 04, 2013 1:41 pm
by Apexracing
Yea sounds like the lock cylinder might be damaged or stuck. Does it unlock with the linkage only?
Thu Jul 04, 2013 8:13 pm
by kutthroatkrow
If by linkage you mean the switch inside then yes. Imma quit messing with it and just buy a new cylinder set with keys.
Mon Jul 08, 2013 1:47 pm
by HeikDiesel
Does the tumbler in the outside handle turn when you use the key? Sounds like something is either stuck in there or you have the wrong key for that lock. You can always redo that lock to match. There a diy on honda-tech that I've seen awhile back
Mon Jul 08, 2013 2:14 pm
by kutthroatkrow
When I bought the car the key worked in the door then one day it just quit working. The key will lock the door still, but that only is 50% of what I need
Mon Jul 08, 2013 3:46 pm
by HeikDiesel
I gotcha so it will lock but won't unlock. I had to re-read the OP. I'd see if I could get that tumbler out and put a different one in.
