Page 1 of 2
pulling engine and trans
PostPosted: Wed Mar 02, 2011 2:04 pm
by beerys95lx
east way to pull engine and trans from an ex coupe?
its all stock so its a d16z6.
PostPosted: Wed Mar 02, 2011 3:33 pm
by chnzgoofball
easiest way that works for me is dropping it from the bottom of the car i used a spare tire on a jack (spare tire facing the cup of the jack) and lifted it from where the shift linkage and exhaust runs under the car and i lifted it around where the shifter goes into the inside of the car
let me know if u need pix of the area so ill can find a pix and edit the pix for u
PostPosted: Wed Mar 02, 2011 4:03 pm
by beerys95lx
no its ok man
PostPosted: Wed Mar 02, 2011 5:33 pm
There's a how-to of dropping the engine in the DIY list :thumb:
PostPosted: Fri Jun 15, 2012 4:15 pm
by crazy-88
is it really that hard pulling the engine/trans thru the top? I'm about to pull my engine also, this is my first front wheel drive car.
I have a cherry picker and engine leveler.
PostPosted: Fri Jun 15, 2012 4:43 pm
by FG2_Andrew
pulling an engine is pulling and engine is pulling an engine.
if you have a hoist, pull it out the top.
if you do not have a hoist, drop it out the bottom.
PostPosted: Fri Jun 15, 2012 6:11 pm
by crazy-88
thru the top it is. one last question. how do u dissconect the shifter linkage from the transmission? or does it just pull out?? I've tryed searching, but all the threads seem to skip the process.
PostPosted: Fri Jun 15, 2012 6:30 pm
by brandoff88
theres a little pin that connects and holds it in, known as the "bitch" pin as its a pain to get out, you slide teh rubber boot away and you'll see it, gl
PostPosted: Fri Jun 15, 2012 7:41 pm
by FG2_Andrew
i've found it best to use a flat nosed punch too.. that is exactly the diameter of the bitch pin. that way you don't mushroom it and have an even harder time getting it in.
PostPosted: Fri Jun 15, 2012 8:00 pm
by crazy-88
damn you guys where right! I didnt even move it a bit. took a short cut and just disconnected the linkage from the shifter itself and dragged the whole bar out with it.
now that the engine is out, I realized the engine is rebuilt. it has that little warranty stamp that melts if u over heat.
you guys think I can just swap out the crank and install new crank n rod bearings?
or should I just tear down and replace pistons, and rings too?
PostPosted: Fri Jun 15, 2012 8:48 pm
by crazy-88
this is what I'm talking about.
PostPosted: Sat Jun 16, 2012 12:03 am
What is wrong with the engine that made you decide to pull it?
PostPosted: Sat Jun 16, 2012 1:05 am
by familyEGuy23
Not trying to Jack your thread but where did you connect the chain to the motor to pull up?
I also have a cherry picker and trying to drop through the top as well
PostPosted: Sat Jun 16, 2012 2:06 am
by crazy-88
teal_dx wrote:What is wrong with the engine that made you decide to pull it?
I broke the balancer bolt and kind of stretched the keyway cut out. tryed to remove the broken pice and I broke every bolt extractor I used.
PostPosted: Sat Jun 16, 2012 3:42 am
by crazy-88
familyEGuy23 wrote:Not trying to Jack your thread but where did you connect the chain to the motor to pull up?
on my engine there is a threaded hole above the power steering pump bracket, then second one on the alternator mount, and the third was clipped on the transmission in one of the support brackets.
this method I believe requires u to remove the radiator an condenser, u first support the engine with the hoist, remove the bolts, then remove the two upper motor mounts completely, then just pull the engine forward to clear the motor mount brackets and finish by pulling te engine all the way up.
