WTB type R motor
yo what's up my homies first off I want to say I'm high as gas prices right now second thing is im looking for this --------------
Found in:
96-01 JDM Honda Integra Type R DC2
Rev-limit: 8400 rpm
Power: 200 hp (149 kW) @ 8000 rpm & 133.8 lb-ft/182 Nm @ 7500 rpm
Transmission: S80 with Helical LSD
S80 spec: J4D (96 Spec: 4.4 final drive), N3E (98 Spec: 4.785 final drive w/ 1.034 4th & .787 5th Gears)
Displacement: 1,797 cc (109.7 cu in)
Compression: 11.1:1
Bore: 81 mm (3.2 in)
Stroke: 87.2 mm (3.4 in)
Rod Length: 137.9 mm (5.4 in)
Rod/Stroke Ratio: 1.58
VTEC Engagement @ 5600 rpm (98specR)
ECU code: P73-003 (96specR) P73-013 (98specR)
Found in:
Rev-limit: 8400 rpm
Compression: 11.1:1
