sidemarker install
the other day i got bored and decided to finally install my sidemarkers. its not the best right up but you get the idea. mine wear akready wired in when i did my tuck. there are 2 wires red and black. when wiring hook them up to the corner lense. if you want blinking sidemarkers do black to green and red to red if you just want them to light up do black to black and red to red. here are some pics
first layout the template that can be found on many forums.make sure you have it level and not crooked
next you will need to cut it out of the fender. i used this simple tool to do so.i went threw maybe 4-5 cut off discs during the whole thing.
next you have it cutout so it should look something like this
now once its cut out you need to make it a little bigger in some spots the template is not perfect. i gradually opened the hole where needed till it fit.
this is what it should look like after when installled
