Removing black paint from rear tail lights! Help!
PostPosted: Fri Sep 16, 2011 3:18 am
by ForneyHatch
I bought my EG with blacked out tail lights. It looks like someone just used some kind of special tinting spray paint on my tail lights. How do I remove this paint without damaging the lights? Any input would be appreciated!!!
PostPosted: Fri Sep 16, 2011 4:00 am
by RWMIII
wetsand. from a 1500 grit to gradual finer ones. then polish the lenses.
PostPosted: Fri Sep 16, 2011 4:02 am
by RWMIII
I have also heard of Goof Off working with that niteshades tint spray as well.
PostPosted: Fri Sep 16, 2011 5:49 am
by Wicked
Depending on the plastic you have several options. I wont be held responsible if you mess anything up trying these, but you can try a nice IPA 90% soak, or a quick soak (under a min) of oven cleaner or brake fluid and then lots of elbow grease with a rag or perhaps a toothbrush and then a quick wash to get any remaining chems off before they eat to much. Id suggest looking these up though before trying any of them, but those seem to be the most common paint stripping plastic methods I've found.
PostPosted: Fri Sep 16, 2011 8:02 am
by Flatland_EG
I thought of chemicals as well but personally I wouldn't risk it, I'd definitely go with the wet sand and polish route, then hit them with some good wax to finish. :thumb:
PostPosted: Fri Sep 16, 2011 1:04 pm
Don't try aircraft remover. I tried that on a set of honda tail lights back in the day and the surface of the plastic started to get a little soft.
PostPosted: Fri Sep 16, 2011 1:45 pm
by familyEGuy23
I've used acetone on my OEM headlights back in the day worked good for me but i don't know if it will have the same results for the taillights
Re: Removing black paint from rear tail lights! Help!
PostPosted: Fri Sep 16, 2011 3:57 pm
by 95cpeEX
ForneyHatch wrote:I bought my EG with blacked out tail lights. It looks like someone just used some kind of special tinting spray paint on my tail lights. How do I remove this paint without damaging the lights? Any input would be appreciated!!!
paint thinner works really well, i have had to remove tail light tint before cuz someone sprayed it a little too dark and i used paint thinner and no issues at all, just takes a little while to get all the paint off
PostPosted: Fri Sep 16, 2011 5:55 pm
by eg-guy
acetone and paint thinner will work, but... they will also f*&^ up the lense if too much is applied. and you'll have to wetsand after anyways if you don't use the right amount so i would just wetsand them from the begining and save the extra money. 1500,2000 then pollish like stated above.
PostPosted: Wed Sep 21, 2011 1:22 am
by necropaulis
gasoline or nail polish remover, and a rag.
