Appearance, Paint & Body Work
By jayEGR
#199968 it came as a kit for 188. and some change but i was trying to find it through my history but doesnt show up srry man just look up kits for it came as a package :thumb:
By ct126x
#201573 Okay I'm about to order some ebay blackhousing lights. Should I go with one piece (not the ricer ones, but the blackhousing with amber corner) or should I go two piece? Reason for asking is because my corner lights stick out a bit from the bottom and I don't want it to do the same when I get the new lights.
By jayEGR
#201648 i like the two piece but dnt know why ur lights are poping out must be the metal thats sitin on the heads and cornerlisght may be siting light that but if not i like the two piece more jdm look i say i like mine as u see sits rigtht :thumb: :thumb:
By ct126x
#201684
jayEGR wrote:i like the two piece but dnt know why ur lights are poping out must be the metal thats sitin on the heads and cornerlisght may be siting light that but if not i like the two piece more jdm look i say i like mine as u see sits rigtht :thumb: :thumb:
I just saw the pictures on ebay and it looks like there are two screws connecting the headlight to the corner light. Are yours like that? I don't remember seeing screws attached to my stock ones, maybe that's why they're sticking out. :?
By jayEGR
#201710 the corner lights yea the have one srcrew on the headlight an the to little thing ponitin out goes to the fender well sits on there snugged :thumb:
By ct126x
#202480
chilango41 wrote:Make sure you get the corner light in the little "slot?" on the headlight, or else it pushes it out and looks nasty.
How does this "slot" look like? Can you take a picture cause mine sticks out like crazy!
By ct126x
#202644 I don't recall seeing those on my stock headlights lol. Im gonna take a look later to see if uneven have them Haha
By jayEGR
#203304 me itether mine just have a thing that slide next to the light and srews in :thumb:
By berg89
#203364 So im guessing you have the aftermarket bumper, hood, fenders? There should be two holes in your fender that recieves the two little studs coming off your corners. If you cant make it fit then it maybe cus you have the wrong corners from a different civic. You should post pics of your problem if u cant figure it out.
By ct126x
#204738 update: I installed them last night and fitment was perfect. I wasn't expecting it to fit so flush, but they do! Haven't had time and the tools to put on my fog lights. What other options do I have to cut the bumper if I don't have a dremel? On another note, my fog light switch came with all 3 "switches" the other two doesn't serve a purpose. I will have to take a closer look at the switch, but would it be possible to take those extra 2 switches out? I bought the same kit as jayEGR
#204739 i used a kitchen knife when i cut mine, but dremal its the best
but if you need help, I did a DIY on the foglight install and wiring
its on a sedan, so the cutting is gonna be diff on the bumper, but the wiring is the same
http://civic-eg.com/viewtopic.php?t=146 ... 0ef38a8103
By ct126x
#204740
94_jdm_ferio wrote:i used a kitchen knife when i cut mine, but dremal its the best
Haha, I was going to use a utility blade, but I figured it would take forever. How long did it take you with the kitchen knife?
