By El Duende
#119389 So going from 175/75-13 to 185/65-14 or 195/55-15, how much would it affect acceleration? The stock steelies mustn't weigh much, so I think it would be hard to find lighter wheels in any size, unless they were tiny 13"s as well. I ask because the wider tires should benefit the Civic.
#119395 Putting a taller Tire on your car will effect your accerlation. Its physics, However on my Dx Sedan I have not noticed a huge impact on Performance going from the Stock 13's to my 15" LS Web's.
However the handling and Ride Comfort is much better after getting the bigger Rims.
So 195/55-15 or 195/50-15
:thumb: :thumb:
By mistergou
#119447 get some 15z an you wont be sad you will be very :D
most aftermarket wheels are pretty light, plus the extra handling an ride comfort is worth the extra lbs
post some pics when you get some
#119451 I agree, plus 2 sizing
A light weight set of 15" will cost more, but unless you're racing the car then don't worry about the extra weight. The handling of the car will be a huge improvement.
By El Duende
#119667 Sounds good. Thanks for the input!
