225/50/15 Anyone run them?
PostPosted: Sun Mar 08, 2009 10:13 pm
by Death_Blooms
I picked up a set of 15" wheels with 225/50/15s. Was wondering if anyone has ran this size on a civic and if they rubbed. I have one on the car and it seems to clear: But I don't have my motor in the car so I know its not accurate
PostPosted: Mon Mar 09, 2009 1:06 am
offset and ride height will make all the difference. need more details of your setup...
PostPosted: Mon Mar 09, 2009 2:44 am
by Death_Blooms
teal_dx wrote:offset and ride height will make all the difference. need more details of your setup...
lowered 1.5"- 2" max
15x7 I think it's a 38 offset
SportMax 940 15"
PostPosted: Mon Mar 09, 2009 2:53 am
by Greasedmonkey
There is a good chance that it will rub nasty. From the 15x6 +45 your rim is extended 20mm further out and you will have 6mm less room inside, just from the rim. and with 225 width tires Im sure you will rub. You might want to role and pull your fenders. even with your drop.
PostPosted: Mon Mar 09, 2009 3:02 am
by Death_Blooms
Greasedmonkey wrote:There is a good chance that it will rub nasty. From the 15x6 +45 your rim is extended 20mm further out and you will have 6mm less room inside, just from the rim. and with 225 width tires Im sure you will rub. You might want to role and pull your fenders. even with your drop.
Googled the Sportmax 940s it's a +38 offset. I already planned on renting the fender roller tool. I'm more or less concerned with if they'll hit the subframe rail in the front
PostPosted: Mon Mar 09, 2009 3:06 am
by Greasedmonkey
I know its a +38, you said that. Im telling you how much its different from say a Si wheel, or LS meshie. With the offest and width difference a 205 will rub on the inner rail. Mine does on a 15x6.5 +45. It will rub more with a 225.
PostPosted: Tue Mar 10, 2009 12:19 am
by Death_Blooms
Greasedmonkey wrote:I know its a +38, you said that. Im telling you how much its different from say a Si wheel, or LS meshie. With the offest and width difference a 205 will rub on the inner rail. Mine does on a 15x6.5 +45. It will rub more with a 225.
Well shiz. Ahh well, I've got some 205/50vr15s sittin here too. I'll have those thrown on and sell off the tires :-p
Ty
