Correct tyre pressure for 15"?
Mon Apr 28, 2008 3:11 pm
by revslide
What's the exact psi i should be pumping to my tyres(195/15/50) with lowered suspension?
Mon Apr 28, 2008 4:52 pm
by yashep
usually the tire says the correct pressure you should use
Mon Apr 28, 2008 5:01 pm
a lot of tires will say the max pressure on the sidewall, which is too much for driving. I would go around 32 psi and see how it rides & watch your tire wear. That should be a good pressure for street driving
Mon Apr 28, 2008 5:31 pm
by Graham
Front is meant to be a tad higher pressure than the back since there's more weight at the front, but its really up to yourself
I normally have mine between 30 and 35
Mon Apr 28, 2008 5:49 pm
by LowTEC-Derbo
i rock 32 in the front and 36 in the rear. gives the rear a little more swing to help rotate those corners.
during daily driving, its 36 all around.
Mon Apr 28, 2008 6:13 pm
by Gorveatt
I rock 32(cold) all around, but my tires are max 36psi
Mon May 19, 2008 6:19 pm
by thedaemon
I rock about 40psi for better gas mileage and less sidewall flex. It's a bit stiffer ride, but I don't mind.
