will it fit? offset question
PostPosted: Fri Jun 05, 2009 11:30 am
by JDMZC
will this specs fit an eg hatchback?
Pattern: 4x100
Offset: +35mm
Hub Bore: 67.1mm
195/50/R15
currently rolling on
Pattern: 4x100
Offset: +40mm
Hub Bore: 67.1mm
195/50/R15
my car sits 1/2 finger gap in front and 2 finger gap at the back....
i know that the wheels will extend 5mm more....but has anyone actually tried it? any pix?
thanks a lot!
PostPosted: Fri Jun 05, 2009 12:29 pm
by Chance
It'll work! I've seen 16x8 +20 on a hatch 8)
PostPosted: Fri Jun 05, 2009 12:40 pm
it will work and look good too :thumb:
the front might rub while turning hard, going over a bump with the wheels fully turned.
But give it a try :thumb:
PostPosted: Sat Jun 06, 2009 5:39 am
by JDMZC
you mean it will work without rolling the fenders???
Thanks guys....
PostPosted: Sat Jun 06, 2009 1:18 pm
it all depends on your drop, but if it were to rub, I think it would rub in the front since it is lower. the front fender is like thick tin foil, you can push the inner lip up with your bare hands if it rubs.
