- Thu Jun 19, 2008 7:00 pm
#59125
I see a lot of blabla.
It depends on what you're using, and what you're using it for.
If you're going to buy original Brembo Performance slotted rotors, they will not crack.
Yes, they'll make your pads wear out faster, but unlike blanks, slotted rotors will stay straight when you've heated them up GOOD, and they will not crack.
And yes, they can be noisier than blanks... who cares, my tires are louder, and it sounds cool, ánd it scares my passengers.
The main reason that low- and mid-range slotted rotors crack, is because these rotors are blanks that are drilled and effectively just haven't been designed for that... unlike high-range discs like the Brembo, wich have been designed that way.
I like grooved discs best though.
I'd say; stick with Brembo, or OEM (wich effectively could be Brembo blanks as well, so go with Brembo).
