handbrake (e-brake)
Thu May 24, 2012 2:29 pm
by baconsauce
how do you adjustment the emergency brake on the car?
or if it gone bad does it need any part replacement?
thank you and I am not much experience with brakes myself.
Thu May 24, 2012 2:52 pm
by elrompetoto
Take off ur center counsel the one by the e brake handle u will c 2 10 mm nuts or 12 mm not shore put ur ebrake down tighten those up and pull ur ebrake up u will feel it get hard at a lower level
Thu May 24, 2012 3:43 pm
by Stank.EG6.Stay.Nasty
Fri May 25, 2012 3:19 am
by baconsauce
Fri May 25, 2012 3:24 pm
by baconsauce
I could not find those bolt when I took off the center console
do you mean that bolt at close to end of the handbrake?
Fri May 25, 2012 3:44 pm
by elrompetoto
Yeah the one right after the e brake handle
Fri May 25, 2012 4:20 pm
by baconsauce
I just looked at it and right behind the hand brake and all i see is the thing hold wire with no bolts, just little dome and right behind it has bolt that are straight line along the handbrake
Fri May 25, 2012 5:38 pm
by elrompetoto
Send me a pic
Fri May 25, 2012 6:04 pm
by baconsauce
there the bolts next to my thumb
Fri May 25, 2012 6:05 pm
by elrompetoto
U c the One that holds the 2 brake cable that's the one u need 2 tighten
Fri May 25, 2012 6:07 pm
by elrompetoto
U c the spring that is holding the 2 lines all the way at the begging of the line there a but right there just tighten with the ebrake handle down
Fri May 25, 2012 6:11 pm
by baconsauce
its worked, firmly and much better
thanks brah
Fri May 25, 2012 6:12 pm
by elrompetoto
No problem make sure it's not 2 tight and stays on with the handle down
Tue Jun 05, 2012 1:42 pm
by zer0
