Integra rear brake disc brake conversion leak.
92 Eg hatch Dx
Ok guys I come to you again for you guidance, this little car is giving me a work out and i'm stumped. My bro got some integra rear disc trailing arms (I believe that's what you call it) and gave them to me for free he doesn't know what integra they came off of all we know is its ABS. My sis drove the car with the handbrake up and ceased the rear drum brakes so I figured its a good time to put the swap in. Everything went fine when installing the trailing arm complete set up. My problem is the stock drum brake lines (the metal piece that goes into the brake assembly) leaks on both of the rear and i cant seem to figure out why. What i did notice is the drum brake assembly had a nipple looking connection on the inside of where you screw the lines and the disc brake assembly I have doesn't have that on the inside of the assembly. I even went as far as to flare new lines and it still didn't work. HELP ME EG GODS HELP!!!!!!
