will 99 si brakes front and rear fit my 93 eg
Just as the title reads I can get a set of front and rears off a 99 si. Will they fit and will I need any other parts off the car or another car to make them fit. Thanks for any help.
https://forum.civic-eg.com/
EJ1_MK wrote:Yes both will fit, the only thing that is really different is the upper control arm between the eg and ek models other than that the front spindles and lower control arms, etc are all the same, The trailing arms are all the same and you will be find if you have drums you will need brake lines for the disc setup. and you will want the e-brake cables as well.
