Any1 Got 4x100 Front teg brakes
PostPosted: Fri May 14, 2010 9:35 pm
by Eg6H2D
Got a 93 Civic Si.
I want to do a front teg conversion of my brakes. Any one know what's needed? I know 92-93 civic Si/Ex No ABS.
and 94-95 Civic Si/Ex has ABS .
does that mean i have to get all Non ABS Parts? it's obvious yes. but im still wondering.
which TEG from 94-95 is non ABS?
is it the RS?. Can i use those.
PostPosted: Fri May 14, 2010 10:26 pm
by asianrob
ABS/NON ABS will work
you can use NON ABS or you can use ABS parts. it wouldnt matter.
92-95 civic EX/Si
and all 94-01 integras will work.
PostPosted: Fri May 14, 2010 10:38 pm
by Eg6H2D
ok great. so i need rotors, caliper, pads. and caliper bracket?
anyhting else?
PostPosted: Sat May 15, 2010 12:21 am
by Classiccarsrule85
Ok pretty much get the whole front spindle from a integra, which would include the arm,wheel bearing,calipers,rotors,pads etc....
your will need a integra brake line as the EG lines are a bit short compared to eh integra ones.....
I did a GSR brake upgrade on my hatch
comparison to my cx hatch
GSR brakes
Thats pretty much all that you need up there in the second picture
PostPosted: Mon May 17, 2010 8:41 pm
by Eg6H2D
hmmmm ok. ill see what i can find..
ok now isn't the knuckle / spindle the same size as i have now. just the integras have a bigger rotor and caliper?
i know in these EG civics the DX/Cx ones are smaller then mines. ive read before jus cant remember where. then some civic Ex/Si's have the 10in rotors. i believe those are the ones equipped with ABS.
what's the size of teg rotors? RS-GSR tegs?
ii can get an awesome deal on new calipers/rotors/ brackets and pads. i just dont want to go and get some used front parts like pictured above. then later my wheel bearing/hub or caliper goes and need a new one. lol. the ones i have now are good.
lol im just a lil itchy when it comes to getting used things..
