Consequences to adjusting height
Silly question but I just want to confirm. I've recently fitted camber kits but I'm going back to stock very swiftly. If I change the ride height, will it change my toe? Front and rear?
Thanks!
Thanks!
https://forum.civic-eg.com/
Paul Sizzle wrote:Only reason why I ask is that if I lower my car to a point I'm happy with, when I get my alignment done, they may not be able to get the prods over my wheels to align the wheels.
So, if I had the ride height high enough for them to sort all the tracking out, then I can adjust the height afterwards.
This is why I'm asking if it knocks out the toe, if so, how badly?
Sorry, I should of made my first post clearer.
Greasedmonkey wrote:if they cant align your car at the hieght you want it, find another place.
EJ1STYLEN wrote:whenever u adj. ur ride to a certain level or lower ur ride to a certain level ull def. need align. and for sure they'll get to ur front camber upfront...if the shop cant that means the align. tech suck....lol and whenever u change struts u always gotta get align...
EJ1STYLEN wrote:u can say its the toe to...cause if u really ask urself what really cause it to wear like that...for me i think the toe is the more important to me, cause u can run up to -4 degree on stock, but u ust have to rotate it...
Torch_Ind wrote:EJ1STYLEN wrote:
here is typical camber wear
mine look like that too. Time for new tiresTorch_Ind wrote:EJ1STYLEN wrote:u can say its the toe to...cause if u really ask urself what really cause it to wear like that...for me i think the toe is the more important to me, cause u can run up to -4 degree on stock, but u ust have to rotate it...
toe in and toe out will still wear evenly across the hole tire
http://www.familycar.com/alignment.htm
Irregular tread wear signals alignment problems. A saw-tooth pattern (left) indicates a toe problem, and beveled wear (right) points to camber problems. (Courtesy Hunter Engineering)
