subs arnt on
Mon Nov 03, 2008 4:55 am
by egsedanguy
ok i have no idea whats wrong.. i have a pioneer deck wired to a jl 500/1 amp. the amp turns on and everything but im not getting sound. i know is wired properly and the cabels are good. somthing to do with the signal from my deck. i plugd the rca to another deck in a diff car and it worked. so the amp is fine. then i put in a cheap amp in my car and it powered the subs. so why wont my deck work with the amp?????
Mon Nov 03, 2008 5:21 am
by jmsplitfyre
So rca cable and amp is fine, did you check the remote wire? It's the blue wire from your sub to the amp?
Mon Nov 03, 2008 12:52 pm
by OmarG
check your head unit. make sure you have the subwooer settings switched to ON there
Mon Nov 03, 2008 3:58 pm
by JlaudioEGFreak
when you have you your jl 500.1 hooked up in you car running off your deck run a set of speaker wire from the amplifier and put a multimeter to them and see if you are getting any sort of out put at all.
Mon Nov 03, 2008 6:39 pm
by egsedanguy
yes i have a remote hooked up and the sub turned on. when i put my finger on the back of the deck on the rca outputs it starts to make sound. i toched a wire to the rca while still conected and toched the metal on the deck and it works. what the hell is it. bad ground?? i have had this deck for a while and it works with all my other stuff.. is ther somthing on the amp not hooked up right. its all powered on.
Mon Nov 03, 2008 6:40 pm
by egsedanguy
jmsplitfyre wrote:So rca cable and amp is fine, did you check the remote wire? It's the blue wire from your sub to the amp?
you mean head unit to amp?? or am i missing somthing???
Mon Nov 03, 2008 6:56 pm
by BurqueB16
yeah try graounding it in a different place. when my subs stopped working that was the problem. but it could very well be your deck also
Mon Nov 03, 2008 8:07 pm
by jmsplitfyre
egsedanguy wrote:jmsplitfyre wrote:So rca cable and amp is fine, did you check the remote wire? It's the blue wire from your sub to the amp?
Oh yeah, head unit to amp. My bad. And maybe you do have a bad ground since you were saying that it's working when you touched the rca's, etc.
