Audio system in 97 del sol VTEC
PostPosted: Fri Oct 21, 2011 2:28 am
by H-sol1989
I have a 1997 Honda Del Sol. I’m planning to upgrade my audio system. I’m not sure if I did it right but will this work?
Speaker and amp:
Rockford Fosgate Punch P400-4
http://www.sonicelectronix.com/item_989 ... 400-4.html
2 sets of Infinity Kappa Perfect 6.1
http://www.sonicelectronix.com/item_274 ... t-6.1.html
Subwoofer and amp:
RE Audio SXX10D2
http://www.sonicelectronix.com/item_273 ... X10D2.html
RE Audio XTX-3000.1
http://www.sonicelectronix.com/item_358 ... 000.1.html
Or
RE Audio DTS-1500.1
http://www.sonicelectronix.com/item_324 ... 500.1.html
Here are 2 pictures of wiring diagrams. Let me know if I do anything wrong.
speaker and amp diagram:
subwoofer and amp diagram:
PostPosted: Fri Oct 21, 2011 4:12 am
by 1-low-92-EG-Sedan
from what i see the speaker and amp choice is good and the wire diagram is good as well...as far as the sub and amp..i would go with RE Audio XTX-3000.1 (XTX3000.1) for your amp an wire it like this
1-DVC-2-ohm-mono-low-imp by Busone10, on Flickr
looks slightly dif then yur pic but this is the best way to do it...and if you have any more questions on wiring subs use this link http://www.crutchfield.com/S-rvjdVZSTT3 ... iring.html
hope i helped!!! :thumb: ...oh and good luck :woot:
PostPosted: Fri Oct 21, 2011 5:15 am
by H-sol1989
1-low-92-EG-Sedan wrote:from what i see the speaker and amp choice is good and the wire diagram is good as well...as far as the sub and amp..i would go with RE Audio XTX-3000.1 (XTX3000.1) for your amp an wire it like this
Woot I got right with speaker and amp. Haha because I’m having a hard time to find both to be like close enough for RMS. i don’t want to blow up my audio.
Yeah I would go with RE Audio XTX-3000.1 (XTX3000.1) but I’m concerned that how do i hook it up the right way because that amp is not bridgeable? I see that it have 4 speaker outputs so can I still bridge the subwoofer or it will break?
PostPosted: Fri Oct 21, 2011 10:08 am
im 99.9% sure you can bridge any 2channel amp...which should have only 4 spots for speaker wire 2 positive and 2 negative..and to bridge it you just put the speaker wire to the 2 OUTSIDE terminals (one positive and the other negative)...nd if it is a mono amp...witch means its made for one sub...so there should be only one positive and one negative to begin with...but as i look at the pics of the amps i see 4 terminals...but yet they are called MONOBLOCK amps...but just to make it easier on you..if yu go with the XTX-3000.1 use the 2 outside terminals and you should be fine...if you have any more questions just ask :thumb:
PostPosted: Fri Oct 21, 2011 1:38 pm
by H-sol1989
Perfect! I’m starting order this stuff ASAP. I’m sure I will do big 3 upgrade too. if i have any problem and I will ask questions in here.
Thanks for help man.
PostPosted: Sat Oct 22, 2011 6:01 am
no problem..hats why we are all here :thumb: ...just return the favoewhen i have a question.. :lol:
PostPosted: Wed Nov 02, 2011 4:11 am
by 93sihatchguy
Let me know if you can fit the 6.1's in the doors without having to use spacers. I bought a pair but I haven't had time to install them yet. I've heard that the magnet won't allow the window to roll all the way down. This is for a 92-95 civic hatch/coupe.
PostPosted: Wed Nov 02, 2011 4:30 am
93sihatchguy wrote:Let me know if you can fit the 6.1's in the doors without having to use spacers. I bought a pair but I haven't had time to install them yet. I've heard that the magnet won't allow the window to roll all the way down. This is for a 92-95 civic hatch/coupe.
if you have that problem you can put spacers between the speaker and the actual door...there should be enough space to work with so the window doesnt hit..but at the same time not space it too much so you cant get the door panel back on...i had a similar problem with my car...but i have a sedan..id imagine its about the same on a coupe or hatch
