as far as the speakers go, why are you asking about 5.5s? if its because you already have a place to mount them then yes, definitely just buy some 5.5s. there are plenty of very good sounding 5.5s. but if you have no spot for them all ready and easy to install you could go with building a box for 6X9s. they would sound a little bit better just due to the bigger size. you can also get mounting brackets for your side panels in the back seat area. thats the best way..takes up no cargo space whatsoever.
wiring up an amp for subs s extremely easy if you understand what all the wires are for and know what wires it takes to power an amp.
12V POWER CABLE(4-0 gauge wire: best way= goes straight the positive bat terminal. MAKE SURE YOU WIRE A AMP FUSE CLOSE TO THE BATTERY. if you dont do that, your amp will eventually get fried.)
REMOTE wire (20-14 gauge wire..wire it to your remote wire on your stereo[usually blue] straight to the amp. this makes the amp lose power when the stereo is turned off so you dont drain your battery)
GROUND (straight to negative battery terminal or anywhere on the frame)
RCA CABLES (red and black- your "music connection" so the sub will actually play with your music.)
SPEAKER CABLES (positive and negative just straight to your speakers. there are different ways to wire them to your speakers. but you only need to know that if you'll be bridging(combing two or more channels to give more power output) your amp)
and your wires were most likely amp wiring. if they 12v is still connected to the battery leave it in and find the other end. then check it with wire tester to make sure its not interrupted anywhere in the middle.
if you don't know much about sound systems and amps and how they work. id suggest researching it a lot before trying to install one yourself. once you know exactly how everything on a sound system works its very easy to install any components.
hers a real simple diagram of basic amp wiring if it helps
http://tinypic.com/view.php?pic=13yigwy&s=3
