By david10072 - Fri Dec 17, 2010 4:42 am
#228450
So I got my kenwood headunit yesterday, I tried to do the wiring myself. The wiring was cut on my car due to theft. I am pretty sure I connected everything correct. But when I turn the key up, the radio doesnt work. No power at all on the radio. I checked the fuse today #23 15A, the fuse was fine. I didn't trust it, so I went to get a new fuse. The headunit still doesn't turn on. None of my speakers were plugged tho. I don't think I need to plug in the speakers to power the headunit...so here is how i connect it...
Constant 12V+ Blue/White ----> yellow battery wire
Switched 12V+ Yellow/Red ------> red ignition wire
Ground Black ---->black ground
Illumination Red/Black ----> none
Left Front (+) Blue/Green ---- white
Left Front (-) Gray/Black ---- white black
Right Front (+) Red/Green ---- gray
Right Front (-) Brown/Black ---- gray black
Left Rear (+) Blue/Yellow ---- green
Left Rear (-) Gray/White ---- green black
Right Rear (+) Red/Yellow ---- purple
Right Rear (-) Brown/White ----- purple black
I want to know if connected the wire correctly?
and if is there anything I should check? besides wiring and fuse?
I really hope its not the radio itself (radio fuse is fine) The radio is brand new, so I am not really doubting the radio.
Any help would be appreciated, thanks guy.
