Need Help Identifying wiring and connectors on dash harness.
Hiya. So the eg I have is a little old school. I'm the 3rd owner and boy was the wiring a mess... After taking off a couple of the wire taps I noticed some were cut off completely and need help getting pointed in the right direction to clean up this harness.
The car is running on a carb engine so no ecu.
Here's the harness:
This is what went to the head unit that came with the car. It was a panasonic so I doubt this was stock plugs. The harness wirings have also been severely shortened.
What's the reasoning for this fuse add on?
This is what goes into the interior fuse box to power the whole shebang. But what is that blue connector strapped to the harness below the other connectors?
The yellow wire has been cut on this one. And a thick wire has been attached with a single round connector...
Here's the harness:
