ECU, Wiring, Sensors
By -paul
#98175 Does anyone know which wire it is from the distributor that's for the rev counter. Due to the fact my car was originally an automatic, now it's a manual but with the same dash clocks. I'm going to put a manual dash clock in with a rev counter, just wondered if anyone knew which wire it was to link up to the rev counter?
Thanks,
Paul
By RevinEK
#98186 Do u mean a tach? Theres a convient blue wire behind the cluster that u can tap into, check a wire diagram if u can get one :D
By -paul
#98187 Oh is that all it is? Cheers dude :thumb:
By RevinEK
#98189 Oh crap i just reread that, ur cluster with a tach will plug right in no extra work required, good luck :D
By BAXTER_EJ1
#98190
RevinEK wrote:Oh crap i just reread that, ur cluster with a tach will plug right in no extra work required, good luck :D
X2, pull out all three connectors from automatic cluster, and plug them into your new manual cluster and you'll have a tach :thumb:
By -paul
#98276 Awesome, thanks guys! :thumb:
