- Sun Oct 26, 2008 10:51 pm
#76049
ok my car doesnt start with the key. i have checked all the fuses under hood and under dash, all are good. also i replaced the starter and still nothin. i also replaced the clutch safty switch and also didnt change anything. so the only thing i can think it would be is the starter cut relay? i was wondering if that is a oem part i order at napa or do i just buy a relay and switch it out or what.
- Mon Oct 27, 2008 2:56 am
#76091
what do you mean it doesn't start with the key? can you push start it? check your grounds.
- Mon Oct 27, 2008 2:05 pm
#76131
like when i turn the key to ignition nothing happens but if the key is on auxilery or run and i get under the hood and hit the starter plug with the batter it starts. there are no bad grounds i already checked all that. the car runs
- Tue Oct 28, 2008 1:13 am
#76212
sounds like you need a new ignition.
