fuel pump fuse
PostPosted: Fri Sep 05, 2008 8:37 pm
by ikon
i read the sticky and cant seem to find where the fuel pump fuse is located could someone give me a hand. :woot:
PostPosted: Sat Sep 06, 2008 3:27 pm
by suspendedHatch
The fuel pump is powered by the main relay.
PostPosted: Sun Sep 07, 2008 10:49 am
by biretsu89
umm.... i found it under the rear seats... just take them out and you should see a silver plate with a plug :thumb:
PostPosted: Wed Sep 10, 2008 8:26 am
by ShEfA
biretsu89 wrote:umm.... i found it under the rear seats... just take them out and you should see a silver plate with a plug :thumb:
This is the fuel pump alone, but there is no fuse under the seats, at least not in my car!
PostPosted: Fri Sep 19, 2008 9:49 am
by HKS_JUN
it is under the dash on the drivers side bolted on with 1 bolt you cant miss it. as i had the same problem
