No power in car...Need help quick!!
Thu Aug 14, 2008 1:04 pm
by Vtec_Shorty
I left for work this morning and i when i shifted in second, everything died, no stereo no dome light nothin but the 4way flashers. the batterry is full and i just changed my alternator last friday. can someone point me out to where the prob could be?
your help is grately appreciated!
thanks
Shorty
Thu Aug 14, 2008 1:10 pm
by a_CoUpE
try making sure you pluged up everything for the altinator right
Thu Aug 14, 2008 3:18 pm
by Vtec_Shorty
already did, everything looks A1 and still i turn my key and nothing at all turns on. as if i unplugged the batt but when i turn the 4ways it goes on, and if i try to turn on the radio or try to start the motor, nothing goes on at all. its puzzling me like a bitch...
Thu Aug 14, 2008 3:36 pm
how do your fuses check out, under dash and underhood?
Thu Aug 14, 2008 4:15 pm
by Vtec_Shorty
the fuses are all good, wich is even more weird
Thu Aug 14, 2008 7:04 pm
by Ecc0
Do you get ignition lights when you put the key in???
Thu Aug 14, 2008 8:48 pm
by Vtec_Shorty
nothin at all
Thu Aug 14, 2008 9:31 pm
I bet it is a short somewhere.
1. you were recently messing with your electric system.
2. everything died when you shifted into second. that jerks the engine/car a little when you let out the clutch, which may have caused 2 wires to touch.
both the 4 wire plug and the single thick white positive wire are still connected on the alternator?
So the only thing that works is the 4 ways? Even the 4 ways will work with very little juice, much less than is needed to start the car.
How are you checking the battery?
