ECU, Wiring, Sensors
By EG-C-J
#59647 If someone can help me out here. when my car is running the reverse lights stay on. When the car is on the ON but not running they are off. checked the fuses, looked all on line and found nothing. Oh and it is a 5 speed. any reason this would happen :?
By Ecc0
#59650 Might be a ground problem make sure you have a good grounding for all the points on the lighting wiring loom front and back.
