- Tue Apr 22, 2008 12:44 am
#51971
it depends how the ecu is tuned.
- Tue Apr 22, 2008 1:33 am
#51979
no. a switch out of an ECU will not improve your power.
The only way it would is if the ECU has been chipped and tuned. Tuning requires software, (romulator) or burned chip to tune, wideband o2 sensor and a good tuner.
- Wed Apr 23, 2008 10:43 pm
#52298
hondata or aem ems are both a fine way to go but both are a better idea after you have modified the engine internals then you can get the most out of those parts you have installed. hondata is around 550 and aem ems is around a 1100. the tune is going to cost more and is a necessity. find out who are authorized dealers in your area and they can help you get in touch with a tuning facility.
- Mon Jun 09, 2008 7:28 pm
#57873
www.phearable.net i chip p06s and sell em. make 50-60 bucks on each ecu.
- Thu Jun 12, 2008 6:59 am
#58177
so you run phearable?
marvinp8700 wrote:www.phearable.net i chip p06s and sell em. make 50-60 bucks on each ecu.
D16z6. Golden Eagle. AFI Turbo. Precision Turbo. Hondata. CG racing.
618hp, 407tq SOHC 10.68@137
My 92 hatch SOHC build. Quest for +600hp. Check it!
- Thu Jun 12, 2008 8:40 am
#58181
Tunning & chipping isn't something you should just try if you don't know much about it. Find someone who does it and is good at it and have them show you hands on, its also good to have some electrical engineering background knowledge to know about your circuits etc.. on the ecu. Start soaking in the info.
