Page 1 of 2
cluster problem.
PostPosted: Thu Mar 20, 2008 7:13 pm
by DannyCraQ
this is really weird, now this happened before my swap, i think when the other engine blew it might have something to do with it. but i cant figure out what the hell is wrong with it. could it be an electrical shortage? is it an ecu problem? cause my ecu was fine. also when i rev my engine, the mph gauge moves which doesnt make sense to me other than the fact its manual now and the ecu is auto.
okay
heres my cluster when i turn the key one click
heres my cluster when engaged and ready to be turned over
even when i turn the car on, it goes a little higher to 40 mph
im assuming this is an electrical short or maybe a sensor is in the wrong port? :?
can i adjust this?
PostPosted: Thu Mar 20, 2008 7:53 pm
by CivicTypeR
haha, dodgy cluster. You now have 2 rev counters :lol: good luck fixing the problem...
Bump.
PostPosted: Thu Mar 20, 2008 7:59 pm
by DannyCraQ
yea thats exactly what im seeing, is the RPM gauge and MPH gauge revving at the same fucking time.
its pissin me off. :thumbdown:
PostPosted: Thu Mar 20, 2008 8:17 pm
by DannyCraQ
PostPosted: Fri Mar 21, 2008 2:56 am
by asianrob
crossed wire?
PostPosted: Fri Mar 21, 2008 9:35 am
by CivicTypeR
Ground problem?
PostPosted: Fri Mar 21, 2008 6:16 pm
by DannyCraQ
well i was told it might be my VSS, but i wouldnt think so seeing in how its a new VSS in my tranny. but this also happened before i put my swap in.
PostPosted: Fri Mar 21, 2008 6:27 pm
by Civic_HatchSI
did u ever take the needle off? because it looks like it just needs to be set.
PostPosted: Fri Mar 21, 2008 7:52 pm
DC4rob wrote:crossed wire?
my guess too... I'd say it might have to do with the tach install. did you put that in before you went to manual?
PostPosted: Sat Mar 22, 2008 4:18 am
by DannyCraQ
nah i installed the tach afterwords.
PostPosted: Sat Mar 22, 2008 4:19 am
by DannyCraQ
also never took the needle off. do i have to set it with every swap? cause before on my buddys car we didnt.
Re: cluster problem.
PostPosted: Sat Mar 22, 2008 5:15 am
DannyCraQ wrote: also when i rev my engine, the mph gauge moves which doesnt make sense to me other than the fact its manual now and the ecu is auto.
so you are using an auto ecu after swapping a manual transmission?
PostPosted: Sat Mar 22, 2008 7:40 pm
by DannyCraQ
i already converted it
would it do that?
PostPosted: Mon Mar 31, 2008 4:35 am
by id3379
mabie you converted it wrong ? idk
PostPosted: Mon Mar 31, 2008 4:42 am
by IdealPerformanceIndy
Seems like a grounding issue. Just make sure everything that you've messed with lately around the cluster or dash electrical is grounded. If the VSS is failing, it will bounce at random (or register nothing at all) after the vehicle is in motion. The vss or wiring to the cluster is getting voltage when you switch on 12v. So, I would check near the cluster. Got an alarm? Stuff like that. And then a nice backup is to always check a "known-good" cluster. It should only take about 10 minutes start to finish to pull one from a friend's EG and pop it into your car, see if it does the same thing, then re-install it in his vehicle.
